anyone know how long a pyronix deltabell E will sound for?...
S
skuba
i need to relocate my primary keypad which is connected to a scantronic i-on40 control panel. i've disconnected the battery in the control panel, but when i turn off the mains the siren obviously sounds. unfortunately, i am unable to access the siren physically and i can't see an option in the control panel menu to enable engineer hold off. does anyone know how long the battery will take to drain in a pyronix deltabell E? or if you happen to know how to disable it using the control panel that would also be good
thanks
thanks
Standard cutoff after 15 min?
