Anyone run a Megaflow cylinder at 4 bar pressure?
Status
Not open for further replies.
12 Sep 2018
Manchester
Yes I know it invalidates the warranty.
And I know the recommended operating pressure is 3 bar.
But on a large unvented system (3 showers, 4 toilets, 4 storey house), if I was to fit a pressure reducing / fluctuations valve with a return / bypass and PVR and set it to 4 bar to match the mains pressure is that safe?
I know cylinders are pressure tested to 15 bar but has anyone actually upped the pressure slightly without blowing their house up??!
Mods note:
To comply with regulations in the UK unvented cylinders of this size can't be altered from the manufacturers specification in this way.
Whilst unlikely the potential damage from a cylinder is similar to a gas explosion therefore we will not allow posts about modifying them on the forum.
Regards
Mod
Not only void the warranty but your home insurance as well.
Yes that's a fair point I hadn't considered. Of it did blow up. How likely is that though?
My solution to having mains pressure showers is a vented cylinder providing copious hot water at low pressure, 6 foot head, to taps.
The shower is fed with mains pressure water that is heated by passing through a coil in the top of the cylinder. A bespoke cylinder but it cost less than an un-vented cylinder.
It should be possible to produce a cylinder for an un-vented system with an extra coil for a supply at a higher pressure than the working pressure of the cylinder
Status
