Hi
I have an alpha 240E combi boiler which has a very slow rate of hot water coming from it. When the water is running the boiler is very noisey and appears to heat the radiator at the same time. The hot water goes hot and cold and can only cope when the tap is basically dribbling.
Is there a two way value from the mains inlet somewhere which is functioning incorrectly.
i.e Trying to heat the radiators and the hot at the same time ?
The central heating works fine when no hot water is required.
Many thanks Dave Halliday
