apollo 30/50 boiler
5 Feb 2004
i have a problem the boiler does not switch on when the stat tells it to and when it does fire up it will switch off at any time, i have fitted new stat but still the same problem,can anyone help? :cry:
i still have the problem boiler will not fire up even though now i have replaced all thermostats in the boiler, high/low/and thermo coupler + wall mounted stat :confused:
Time to call in a corgi. Maybe you'll let him see what make the the boiler is.
I may be wrong but I think the clue was in the title :LOL:
you are not wrong, but the point is more information is needed. the poster is not forthcoming with information, how are the regulars to know what happened prior to it going wrong, that was the whole point of the "announcement" in this section, but the owner thought it that good they made it an annoucement, as origonally it was just a post.
Most new people do not read instuctions for forums, and then "moan" when they get no responce or the message is moved or edited, similarly with signatures
