Hello I am having problems with an Apollo Fanfare 30/50i.
It will fire up for approximately 10 minutes then cut out, then fire up again for about 45 seconds then cut out again, repeating this.
The heating system is a microbore system thinking this was a flow problem and have flushed this through every year for the last five years with a system cleaner. Thinking it maybe a flow problem I have just switched the boiler over to the hot water circuit but it repeats the same thing,
The overheat cut off has been replaced and the high and low thermostats have been checked but it makes no difference to the boiler if switched into low or high. The pump has also been replaced.
Im beginning to think it is either a defective solenoid valve within the gas valve or a fan pressure switch, which Im probably going to have to leave to a gas safe engineer.
Any suggestions to the possible cause and rectification would be much appreciated??
