B
breezer
If your appliance goes wrong.
First thing to do is consult manual, if you have no manual search the web for one. (or search for manufaturer)
2nd after doing that, and the manual doen't help read posts on this forum.
3rd, if that doesnt help post message, stating what appliance is, make and model of appliance. what is wrong and what appliance does or doesn't do, any thing on its display (if fitted)
Some things are easy to fix, like water not coming in or going out but most other things are best left to a service engineer of the appliance (i used to be one) the reason i say this is because in some cases if a part fails it is doing its job, because another part is actually at fault which is not aparent to you.
also for example a door seal, there are a few tricks in fitting them which makes it easier, but have you got the RIGHT door seal, (i have even seen a washing m/c that an independant engineer fitted a door seal that was the wrong one!)
Also some "replacement parts" are similar , but need slight altereration or slight wiring changes which are not aparrent.
I therefore suggest that unless you can see the part from outside of the appliance, get an engineer in to do it for you. Most manufacturers have their own team of engineers specialy for this.
If you get an independant company, ask for call out charge (if any) and insist on having genuine parts fitted, as they will last longer.
one other note.
Sometimes a washing m/c will stop mid cycle so it is assumed it is the timer / programmer is at fault, quite often it isn't its the heating element as the m/c has stopped and is actually waiting for the water to get to temperature, but as the element is no longer working the m/c will just "sit there"
but an engineer (and now you) will know this, so get an engineer to change the element as, as previously mentioned sometimes something else goes too which is not aparent.
some jobs are not for the diy person
one other note.
