I have done the first coat of joint compound. Will be doing the second coat. Do I need to use three coats? The third being the finishing? Or can I just do two? Read that joint compound can be used instead of finishing plaster. I am tapering not shimming.
How long do I have to wait after final coat, sanding, before applying a primer?
Also what primer do I use? It is a bathroom, so I will be using bathroom paint. Read suggestions about PVA and diluting paint as a primer. Would like advice on the best method.
Mostly buy from Wickes and B&q.
Also stupid question, but is there any way to shower until bathroom is painted? Like using a shower curtain, or is it best not to risk it? Like having a bath instead and keeping door open to let humidity out? Sucks, because I only have one bathroom.
