I've read a few threads about the WP1 Shower Tanking kit and I want to use it when I refit my bathroom next month.
I intend on using Knauf Aquapanel, tank and then apply tiles.
I have been reading the Bal data sheet...
http://194.223.92.131/pdf/Technical...hnical Data Sheets/Bal_WP1_Tanking_System.pdf
And this suggests that for tile backer board you need to
"Apply a skim coat of a BAL cement-based adhesive modified with BAL-ADMIX AD1, prior to tanking. For wall areas BAL-GRIP may be used. Allow adhesive to dry."
I am slightly disappointed as I thought the kit would contain everything I required.
I guess I should follow what the data sheet tells me, I am interested to understand if anybody has just used the primer and WP1 on Aquapanel without doing the step in the data sheet?
