appolo fanfare,pilot light/water temp
17 Feb 2004
i have a situation whereby my pilot light will go out on boiler switch
set to high[thermocouple has been replaced],also wether my boiler switch is set to high or low my rads are almost ,it seems,at boiling point i have scalded my arm and am very concerned for the saftey of my two young children can anybody help ps i have also replaced the cylinder stat and run a descaler through the circuit hope someone can help
cheers kieran
on the apollo fanfare {horrible boilers - dangerous thing } the thing whoch causes red hot heating is the high low stats or boiler stat. The thermocouple will go out but shouldnt need replacing. Is your boiler banging like someone hitting it with a hammer? whats your hot water like? make sure if ANYONE does any work on your boiler the case seal is intact, this has caused so many deaths. the case must be sealed not only to keep fumes in but the fan and gas valve work with a sealed unit.
Now incase i read your post wrong, i assumed the raidators are really hot? in that case changing a thermocouple woundnt fix it.
always try to replace limit stats, - boiler stat.
good luck mate! :D
