Approx 21mm black plastic water main pipe.
ICF
26 Sep 2004
I want to break into the main water supply pipe which is black plastic and about 21mm in dia.Do you think that 20mm MDPE fitting would fit this pipe?
nope it wont
but you can buy an insert to convert it
try drain centre
:oops: Can you direct me in the right direction there is to much choice on drain centre's wesite :oops:
take a sample to your local store
they will sort u out
That sounds simple but if I do that then won't the pipe will be to short to re-join back up.
you are going to have to repair it wif blue poly as the black stuff is now very obsolete
so it dont matter do it just as long as you can get a push fit joint on it
This is :eek: very scary :eek: .Will there definitely be a fitting for this pipe size :?:
there will be the fitting aint the problem, it will be the insert they may be a bugger
any hoo the old black stuff only came in two sizes so splash out and pick up inserts for both and RObert will be you mothers Brother
What were the two sizes :?:
Will it be a push fitting or a compression fitting :?:
:rolleyes: it sounded a bit doubtful or uncertain :rolleyes:
Go easy on me I'm learning all the time ;)
Yer tiz ;)
