aqualisa 609 leaking i think
13 Jan 2014
Surrey
Hello wondered if anybody could help.
We have a built in aqualisa 609 thermostatic shower with 2 leaks on the adjoinng wall (so back of the shower). The first leak is approximately 20cm above the mixer unit, and is roughly 10cm squared. The 2nd leak is again on the same wall which looks like the the area bottom of the shower, this area is a lot larger roughly 30cm by 60cm so i am guessing the bottom of the shower needs resealing. I have removed all the silicone and the shower has not been used since before xmas but both areas are still damp.
before we starting pulling the shower apart would you think the leak is coming from the shower or the pipe work. We have a bathroom directly above this shower, do you think this may have something to do with the leak?
Any advice would be welcome
Start at the highest place that you think you have a leak and work down from there. Pictures might help but really with hidden leaks such as this anything have happened.
Good luck!
