Hi there.
I have just fitted an aqualisa Midas 100 shower that is running from a salamander CT50 shower pump on a gravity system.it works fine when I have just hot water or just cold water running through it but as soon as I turn the temperature control knob to mix the hot and cold to the desired temperature between 28 and 38 on the control the shower keeps pulsing then dies on me.i took the shower bar off the wall then turned water back on and the pump kicks in straight away and the water comes through fine,nearly shooting over the end of the bath so I think the pressure is fine so pump is working ok.i put the shower bar back on and again when it was fully turned to hot it was good and likewise with fully cold but again when I try mixing the hot and cold it ain't having none of it it keeps pulsing.can anyone please help.Cause I am fed up with sitting in the bath with cool water as it seems to work sort of ish when I am lower but still pulses but not as much.
Any help would be a brucy.
