Our Aqualisa Aquastream (97-03 model) pictured here:
http://www.aqualisa.co.uk/parts-sto...hermostatic-and-manual-integral-power-shower/
has a constant leak from the gasket (between the cartridge and main unit), dripping slowly into the casing. It's happened on and off for the past few years, which has rusted the bottom two screws holding the cartridge in place, and results in a drip from the casing into the shower trap and a nasty build up of limescale in the casing at the bottom.
The gasket seems absolutely fine - in fact looks as new, I'm certain it is definitely leaking from the gasket area, so will silicon grease improve it (or is it useless?), or should I go for some sealant around it, or...? The leak over time causes the microswitches to fail, and I've already replaced them twice in the past 4-5 years.
Any tips? Other than this, the shower is fantastic, had it since approx 2001 and we have at least 2 showers a day with it.
[edited to add about microswitches]
