- Joined
- 23 May 2023
- Messages
- 1
- Reaction score
- 0
- Country
I've have had my Aqualisa Quartz Digital shower for about 6 years and haven't had any issues up to now. I recently turned down the Combi Boiler so to heat to the Eco setting. This turned down the heat for the shower as expected, but not warm enough so then changed the boiler back to 75 degrees.
From this point onwards the shower dial has to be turned to the max, to get decent heat. If you go back a few notches the temperature cools off significantly.
I have turned off/on the main electrics to it so it resets, which has not worked either. Other than that the shower works fine and is still powerful.
Can you advise what might be the issue and how it can be corrected?
