Hi I have and aqualisa Aquatique Victorian Style Thermostatic Mixer Valve (concealed body)
This is connected to a pump, on a gravity based water system.
I have the problem that the water that comes out of the shower is at best luke warm, even though the water at the hot tap at the basin in the bathroom itself is piping hot.
If I switch the pump off, the temperature does increase (but still not very hot).
I know I actually have low cold water pressure, hot water pressure is fine.
Does anyone know if the temperature problem would be solved by replacing the cartridge or is is a problem with the pump?
