Aqualisa shower problem
17 Mar 2005
i have a Aqualisa classic Aquavalve and it has started leaking from the valve (water dripping from the temperature control leaver)
as well as the head dripping i assume it can't be serviced ?
im not sure how old but it looks the same as the ones i have seen online do i need to replace the cartridge and if so will all the color codes fit as it was there when i moved in and i have since had a combi boiler fitted so it may be the wrong one ?
many thanks
You can indeed service the valve, but I would contact Aqualisa and ask them which cartridge you should fit.
