Aquapanel fixing pitch
14 Sep 2008
Hertfordshire
The instructions for fixing Aquapanel, say to fix using screws at 20cm centres, at the top of the wall, bottom of the wall and to battens at a 40cm pitch across the boards. It says that because shower hardware is often in the centre of an 80cm section, that this may involve using 3 battens instead of 2.
I have a stud in the corner of the room, one at 80cm that i added for the shower enclosure and there is another between them at 60cm from the corner, so I have gaps of 60cm and 20cm.
I'd rather not add another stud if it can be avoided as there is a lot of pipework in the way. Would the addition of some noggins be sufficent to oversome the deficiency in stud placement?
