Aquapanel on small stud wall...
1 Jan 2008
Hertfordshire
ive got a small stud wall (hide shower pipes)to aquapanel thats approx 850mm across and 2300mm high. I've bought 2 sheets of 1200x900x12.5mm aquapanel, am i ok to put these one on top of the other or do i have to cut the top board in half so that joint is staggered? Seems a bit daft if its only two panels?
Given the dimensions these will also be fitted so the writing on the panels is vertical rather than horizontal or is that a big no no?
Fit it how you like but use the correct washers and screws for fixing it to the studs. I prefer hardibacker.
Edit: got 16 sheets of it to put up this week on a bathroom job :sick:
