Hi all
1930s solid brick house.
Bathroom, some of the plaster came off with tiles on the outside wall, so did the sensible thing and removed the rest of it (heavy tiles being put up).
Not a very big area, big window in there too.
Roughly 6ft tall by 2ft 2" wide, then another 15 " by 42" under the window.
The rest of the walls are new partitions with either plaster board or aqua panel on (depending whether they're near the bath or not)
Part of me is tempted to screw aqua panel directly to the brickwork, but I'm sure I read somewhere it needs air behind it.
My concern is two fold.
Am happy to give plastering a go but I need to tile the room ASAP. Could give it maybe 3 or 4 days max for the plaster to dry out (I've read it takes months).
I'm also worried about the weight of the tiles. They are 16" x 12" x 10mm, box weighs a ton, but maybe I'm just being silly (of course a box of tiles that big is heavy ...) and when looked into various skimming tips on the web, have seen it mentioned about the weight of tile being put on, which is another reason I was thinking aquapanel.
What do you guys suggest please, it's a sound, dry (but not perfectly level) brick wall.
Bonding (or something else) followed by a couple of skim coats
or
aqua panel, maybe with tile adhesive used to dot n dab just to get it level before I screw it in place?
many thanks
or
many thanks
