I’m currently upgrading the lighting unit for an aquarium by swapping the original T8 fluorescent tubes to T5 versions and changing the electronic ballast.
On dismantling the unit I realised that the existing metal cased ballast has an earth connection which is not being used. I assume that as the unit is sealed to make it waterproof, made of plastic, and has no exterior metal parts it is not necessary for it to be earthed?
My question is whether it would be safer if I were to connect the earth on the new ballast which is also metal cased?
Whilst the unit is supposed to be waterproof, I gather it is not unheard of for some water to find its way into this type of unit causing them to fail. The circuit the light unit is plugged into is protected by a 30mA RCBO which should provide some protection from shocks if this were to happen.
However in its existing configuration if water gets into the unit it would surely not cause the RCBO to trip as there is no alternative return path for the current (unless your receiving a shock by touching it!)? If that condition was to occur then the unit could potentially be in a dangerous state where it may be wet and live to the touch.
By connecting the earth on the ballast in the unit surely it would make it safer? If water was to find its way into the unit there would be a chance the RCBO could be tripped by current running to earth if the ballast got wet.
So opinions welcome..... Would connecting an earth make it safer or not?
