Little conundrum here.
2 doors next to each other (well about 300mm between but near enough). One door opens inwards into the room, the other opens outwards (into the ensuite). Doors are the same height but of course the door linings are different heights on the underside of the top rail (due to inward/outward opening difference). Which means if I fit the architrave the usual 8mm or so away from the door, the top architraves will be parallel but one 20mm higher than the other (door linings had to be very wide so they're made of 19 x 200 PSE with the rebates 19 x 160 PSE. Bit chunky I know but there we go).
The obvious (with hindsight) solution was to have the door into the ensuite 20mm higher than the door into the bedroom (you can't see both doors from the other side so height difference won't matter). Too late for that though.....
Current plan- the architrave I'm using is 68 x 19 Ogee, it has quite a wide flat on the outside edge. So plan is to rip 5m down by 16mm- this will leave some flat on the outside edge- and fit at 6mm on the inward opening door. Then fit full width to the outward opening door at about 2mm (exact position depending on where the straight line ends up) to make the tops of the architraves parallel and level.
Is there a better bodge, have I missed something blatant?
