Hi Guys,
Okay plastering is now done and looking very good. Plan on putting on a mist coat this weekend, but have a couple of questions regarding the order of attaching the architraves, skirting and ceiling coving?
Has anyone got any tips for attaching these?
Does the architrave get attached to both the wood of the door casing and somehow glued to the plaster? How? Should these generally be done before or after hanging the door?
Should the architrave go down to the floor boards or leave a small gap so the carpet goes underneath?
Similarly, the skirting although I've done this before with rawl plugs and grip.
What about the coving? I know you get the adhesive, but is there a best way of doing this. Sure in our last place the corners were small sections with longer sections between these. Is this normal or should you try to have the joins towards the middle?
I guess you just measure equal distance inwards from the ceiling and down the wall to ensure it's level.
Lastly, is it okay to put the mist coat on before the architrave, skirting and coving?
Thnaks
Kyle
Thnaks
Kyle
