architrave
16 Jan 2006
Newport, S Wales.
how far back should the architrave sit from the edge of the door frame when fitting? is 10mm too much?
thanks
5 - 10mm is fine, if its your house its your personal preference, but 5 - 10mm is a good guide.
aim for 10mm then you have a smallbit off tinkering room if you make a little mistake
Or if you're as rough as I am you could allow a couple of inches then you have a lot of tinkering room if you make a big mistake! :D
ok that sound fair enough and if you make a few mistakes it will fit the cat flap :D :D :D ;)
