Arcing when inserting mains fuse in consumer unit
ABN
12 Sep 2005
Surrey
Just changed a faulty wall socket, when I replace the consumer unit fuse (fuse wire type) with the consumer unit switched on I could hear a small amount of arcing as if drawing current. Everything on that fuse circuit was switched of at the wall.
Is this normal due to the natural capacitive / inductive load of the wiring or is it likely to point to a more serious problem.
Probably something else on that circuit that isn't turned off, like a bathroom fan or something else hard wired. Not really anything to worry about.
Is this normal
It's normal if there is a load connected.
What's not normal or safe is shoving a fuse into the fusebox while it's live.
If a fault exists on the circuit, the fusewire will vaporise and burn your hand.
In future, switch off before removing or inserting fuses.
Thanks for the replies.
I realise its not good practise to insert fuse while power is on and in future will not do so.
90% sure nothing was connected but will check again.But if nothing is still conected or hardwired what could becausing the faint arcing noise? Could not see any visible arcing.
I think it must be down to that other 10% ! As has been said/implied, if absolutely no current were flowing when you re-inserted the fuse, there would be no such sound - so I suspect that there must have been something connected to that circuit.
Kind Regards, John
