I have a basin here with tap holes that measure over 30mm in diameter. The tails on my taps are "15mm" or whatever, so about 20mm OD in practice. So there's loads of lateral play no matter how they're tightened up.
Also, the washers I've got have an OD only just larger than the holes in the basin! So they're hard to get sat centrally and tend to collapse into the hole when the tap is tightened down.
I dug the old basin out from the pile of rubble on my drive and it turns out the holes on that are the same. And, the washers on the old taps are the same as the washers on my new ones. I didn't pay much attention when removing them, weeks ago now, so can't remember how secure they were.
But anyway, the upshot is that when tightened down (tap-rubber washer-basin-rubber washer-plastic back nut) the tape rotates very freely indeed.
What's the best solution? Wider washers? Fill everything with silicone?
If I silicone it should I remove the top washer altogether so the flat base of the tap body contacts the basin surface?
EDIT: "fix-a-tap", some bits and pieces to correct this issue. Recommended?
