I have 3 new rads to fit in what will be a new system. These are 300mm wide, 1500 tall, vertical tubes, double. It's such a short distance across the 300 width, I can't help wondering if the hot water will all go up as it should, or some might shoot straight across to the return, and reduce the rad output.
Is it normal to always bottom feed, with even tall narrow rads like this
(Top feed would be possible, - I could hide microbore behind dot and dab, but it's untidy, and not so easy).
