...On how you use a shower.
Electric per Kw hour is 3 / 4 times as expensive as gas. Electric showers tend to consume less water and waste less water whilst you run it to get it to temperature. If you pay for metered water, that is an extra cost, besides the kw consumed.
My daily 9.5Kw max. electric shower lasts around 2minutes, at 29p per Kwh, so around 9p for my shower.
I'm a firm believer in have a plan B, and sometimes even a plan C - my electric shower serves as a plan B, should there be a failure in my gas water heating system.
Wow, you only spend 2 minutes in the shower?
For what it's worth, same here - and my Plan B has hardly ever had to be invokedI'm a firm believer in have a plan B, and sometimes even a plan C - my electric shower serves as a plan B, should there be a failure in my gas water heating system.
One of the benefits of prepay meters is they display the actual amount of credit stored in them and it really is a simple matter to use ones eyes and read the display,Not sure how you are working out your costings. But according to your figures for a short shower costs are similar.
It goes into the inefficiency of the whole installation... running a 27KW gas heater for nearly 50% more time then cooling down the excessive heat it produces.Bearing in mind electricity is 4 times the cost of gas you must be using 4 times as much energy with gas. Where does all that energy go?
Indeed but I believe it is currently the cleaner option and getting cleanerElectricity of course also causes pollution, it is just not in your back yard.
The waste of clean drinking water in these times of drought really should not be ignored.The cost of water is negligible and can really be discounted.
Can you please think about that one again and reconsider your error.Mixer taps don't waste gas. When you mix you reduce the flow of hot water and replace it with cold and so reduce gas consumption.
I'm not sure about his figures either. However, if there is appreciable hot water pipework involved, "where some of the energy goes" (although I doubt anything like three-quarters of it) is into heating the pipes, and hence house - which, at least in summer, is 'wasted'.Not sure how you are working out your costings. But according to your figures for a short shower costs are similar. Bearing in mind electricity is 4 times the cost of gas you must be using 4 times as much energy with gas. Where does all that energy go?
I have to agree but on those rare occasions plan B is very handy.For what it's worth, same here - and my Plan B has hardly ever had to be invoked
Kind Regards, John
Reading directly off the meter is irrefutable.I'm not sure about his figures either. However, if there is appreciable hot water pipework involved, "where some of the energy goes" (although I doubt anything like three-quarters of it) is into heating the pipes, and hence house - which, at least in summer, is 'wasted'.
To be fairly pedantic, per recently-announced 'price caps, the ratio is now down to 3.5 times.
That arithmetic would be correct IF one were comparing a gas boiler running 'continuously flat out' at 27 kW with an electric shower drawing 10.5 kW continuously.However running a 27KW gas boiler for approx 40% longer is approx 3.5 times the energy used in a 10.5KW electric heater.
That just happens to be the ratio you quote so generally I find my beliefs to be confirmed.
