I have a dust allergy and decided I will throw my carpets away and restore my floorboards. After throwing it away I gave it the floorboards a scrape, hoovered it and wiped them down. These boards are really old btw and still have paint marks, blacks stains and other such stuff on them.
Anyway in order to see if floorboard restoration would work, I used celetape and covered all gaps including skirt boards. Now as far as I'm concerned the dust should have stopped coming up however I am still detecting a fair bit in the air.
before I started taping I knew there was a strong odur in the air and I don't think it was the smell of wood, perhaps some of those stains on the wood. After taping that smell reduced by about half.
1. Why is there still significant amount of dust in the air even though I have taped and hoovered the boards. is it likely there is still dust on the surface of the boards or coming through gaps even though they have been covered with tape?
I just used some simple brown tape but so long as there are no holes I see no reason why dust should come up.
2. If it is on the surface and I can't see it, how can I ensure it gets removed?
3. The wood is really old and i'm thinking maybe dust is coming up through the planks or maybe not since i can't see any holes. Anyway do you know what might be causing dust to come up when wood is meant to stop that.
There is no point me restoring the boards if it won't solve my dust problem.
