Are these damp spots in the lime render signs of impending damage? NHL 3.5, 3:1 sand to lime
11 May 2021
DO I have to get a surveyor to find out whether persistent wet patches in lime are a bad sign? I never see patches in anybody elses render when it rains. thanks
its a victorian property circa 1850ish build and this is the stone underneath, granite?
spent a lot of money on this, pretty mindblown if its starting to fail.
The damp spots are an unknown because I dont know how the very rough background was prepped or how the render was applied.
The renders at front elevation and back elevation are different - why?
- You have sand & cement fillets at ground/wall abutment. They need to be removed and then the gap made good but render stopped 50mm above ground level with a plastic Bell Cast.
- The door canopy also has a large lump of S&C fillet - you could leave this in place and flash with lead or remove it & flash with lead.
- The S&C plinths at the base of the wall need removing and the render making good - all render should finish with plastic Bell Casts'.
- The render that stops above the front elevation horizontal band might benefit from lead flashing or even a small S&C fillet. I think a Bell Cast would spoil the effect?
- Cracks can be lightly raked out & filled with polyurethane.
- Your window sills should have drip grooves.
- The RWP discharging into earth is wrong, it could do with a trapped gulley & then piping away.
- Do you show any damp signs inside the house?
Yes damp above the middle of the door upstaisr in the new plaster and a crack has formed along the whole height of the house along the boundary between the two. water is entering both houses on either side of the crack.
It's been found that the presence of lime in Roman concrete actually helps it stay stronger for longer; even when cracks form in the concrete the lime reacts with the rainwater and provides a natural sealant to stop further rain damage.
@news.MIT
Research is now being done in future applications to include this technique - so, if lime is present in your mix then the cracks should self-heal over time. Since the building has been around for 150 years it should dry naturally, as the original builders intended.
