I
imamartian
Just had a combi boiler fitted (bear with me... it gets electrical in a mo ), and the sparky they used, has taken the timer away just cutting the wires and leaving them exposed in the hole. Thing is, if i stick a volt stick in the hole, it bleeps as tho there a live in there somewhere...
Also he has left the switch for the immersion heater (obviously the tank has gone), but i've turned that off in the CU.
The timer hole has four cables, two t&e, one three core and earth and another single sheathed earth.
Question is, where's the power to the timer coming from? Would it be live? or could an induced current be setting off the volt stick?
