My Ariston boiler repeatedly locks out, lighting the ignition failure LED, but only when the heating is on. It's been fine all summer supplying hot water, but now it locks out 3-4 times a day. It will nearly always relight as soon as you press the reset button, although rarely I need to wait a couple of minutes before it will reset.
It appears relatively random. Sometimes it will run for hours, other times (usually first thing in the morning) it will only run for a couple of minutes. Typically from cold it will fire once and run up to temperature. Once at temperature, the flame will go out and it will continue to run with the temp reducing slowly. Then it will either refire, or, more usually, the red led will ping on.
Resetting will work, and then it will usually run for a bit before cutting out again in the same way. Once I've done this a few times it seems to run ok for a longer period?
I've drained and refilled it recently when I added an extra radiator and the water ran quite clean. Unfortunately I can't tell if it is related because I did that before turning the heating on this year.
Any ideas? I've spoken to a heating engineer, but he didn't seem confident that he'd be able to diagnose it, because it's intermittent, which wasn't reassuring.
It's definitely getting worse. It's gone from doing it once every couple of days to 4-5 times a day.
