Ariston A1535uk Manual
10 Mar 2005
Middlesbrough
Looking for manual for Ariston A1535uk.
The programmer dial is spinning round at a rapid rate.
AFAIK this is a problem that stems from the pcb
Apparently these can be reset by pressing a sequence of buttons. If I can't get hold of the manual can anyone tell me the sequence?
TIA
1 Switch off machine
2 Select an off position on timer (black dot)
3 Switch on. LED should light up, go off then flicker twice. The board is now re-set. If it will not do this then switch off again and wait 1 minute before switching on - thre LED should then go through the above sequence.
4 If you get no reset flicker it confirms you have a board fault.
Try EMW if you need the board repaired:
www.emwelec.co.uk
