- Joined
- 10 Jul 2006
- Messages
- 2
- Reaction score
- 0
- Country
I have an Ariston Aco boiler fitted last september. Since it was installed i have had a problem where if i leave the CH temp low the boiler will work for awhile and turn itself off when it reaches the correct temperature. However when it tries to re-ignite, to warm the CHW up again, it fails and gives me an error code of A07, which when i had a look in the manual just says the code means the boiler failed to ignight after 7 attempts. Anyone know what the cause of this could be? And recently the boiler has been starting to make a load humming noise when the DHW is being used and when the water is turned off the whole system will fail and the same error code will be displayed. Any help would be good. thanks.
