ariston avtl 125 washine machine stopped working
8 Jun 2011
Hi there!
Im hoping somebody can help me out on a problem I have.
The problem I am currently having is my Ariston AVTL 125 Washing maching which as I have found is the same as an
Ariston AVTL 104 has stopped working.
After turning It on the machine sounds like it begins to take in water then stops. The door light begins to blink and the bottom
right large LED which looks like a bucket of water with an arror over it flashes also. If left on the machine
begins to smell funny, and once tripped the electrics. I then tried to start it again with no water inlet pipe
connected, the same thing happened.
The machine worked fine until it was tipped on its side whhilst being moved. It is 4 years old
Any Ideas will be very welcome. Thanks in advance.
This model or models is not reconised in the uk as your from finland can u contact ariston from your end.
Just found out that code means f01 error, pcb has gone , motor triac on board had failed.
Thanks for the quick responce guys. Both are thanked.
The mother board is what i was dreading. Seems like stripping it down last night was a waste of time then. Is it worth replacing the board or cheaper to get a new machine? :(
Cost about 80 quid but you need the software to prog it as well and that is not cheap
Surely if I send it back to the dealer the part will already be programmed? Anyway, on monday Ill call them up and get a quote using the error code you gave me.
The end result was a fried mother board which cost 150 euros to replace.
What on earth is a Brit doing in Finland? I think we may be slowly taking over the whole world one country at a time.....Enjoy the lakes & saunas buddy!
