Hello,
I'm after some advice on a domestic boiler problem.
It's an Ariston Genus 27 MFFI combi that was working fine until a couple of days ago, nothing has been changed prior to it acting up.
Central heating works perfectly. The problem is that when a hot tap is turned on, the boiler fires and the water runs hot but after 30secs or so the burner goes out and the water runs cold (this is without touching the tap). After 10secs the boiler then lights again and the water runs hot for another 30sec before going cold again.
I'm guessing the flow switch is working as the water runs hot to start with and I assume the diverter valve is also okay as again I do get hot water. Is there a hot water thermostat that isn't sensing quickly enough or do I have the wrong end of the stick? I'm competent to replace components (famous last words) but I need some help re diagnostics.
You should've heard the wife screaming in the shower this morning, soap in her eyes and freezing water coming out of the shower head. Anyway, you get the picture. Any advice would be much appreciated.
Regards,
Gareth
Regards,
Gareth
