Hi . Need some help from an expert- My Ariston LSi 68a Dishwasher flooded on christmas day. Found that the filter was choked. Since then the programme wont move along and the pump continues to run. Ant one got any tips before i need to cal the engineer in?
Flooded base. Power off, pull it out, put some towels at the rear corners and tip it back about 45 degrees. Keep it at this angle till the water stops coming out.
Put it back in place, power on and try it again.
