Hi There
I have the above combi boiler which has begun to heat the rads when I ask for hot water from the taps. However the central heating doesn't turn off so I have to turn it off manually by the power switch.
It also turns the rads on randomly throughout the day and does not shut down. I believe this is because the boiller does do this but due to the faulty part it's not switching off properly.
From my research into it on the forum I believe it's the diverter valve thats faulty, but im led to believe that to solve this problem I can just change the diaphragm inside this which is much cheaper.
Can anyone help me by confirming this for me, and would anyone have a part number to use to get this as there seem to be many diaphragms for ariston, my manual doesn't have this part mentioned in it.
Many many thanks for your help
Glenn
Glenn
