Greetings,
Can anyone help with this one,
I have an Ariston euro combi A/23 mffi which I'm told is over 10 years old. Its started playing up. The central heating side works fine, radiators heat up - no problem. The problem is when I put the shower on in the morning. The burners ignite immediately and the water appears to gradually heat up and then starts to run almost cold. I checked the burners and they are still lit when this happens. I find turning the tap on and off a few times will eventually cause the water to start running hot.
Can anyone suggest what the problem might be ?
thanks
Rob
thanks
Rob
