Ariston Eurocombi MMFi 23 fan
17 Aug 2014
Hi, I have an Ariston Eurocombi MFFI 23 and the fan is making a noise (sounds like drilling concrete in the distance due to catching) and I was wondering how hard it is to change + will I need a new fan inlet gasket while changing the fan.
The boiler is approx 16 years old and up to now I have changed the secondary heat exchanger, diverter valve, pump motor and diverter valve diaphram over the years and have to say the boiler up to now has served me well and found it very easy to diagnose and fix when necessary.
Thanks for any advice you can give.
Ring a professional and ask them ......."how hard it is to change + will I need a new fan inlet gasket while changing the fan.".
Surely its easier just to ask in here. Isn't that what this forum is for?
Why do you have to be so nasty?
I asked a question that's all. If it is wrong I apologize and feel free to point me in the right direction about my mistake maybe by educating me about the relevant part in the forum rules but I take offense at your reply.
In what way have I justified an answer like that.
First couple of lines from the forum rules:
1) This is a friendly site and we ask that everyone is treated with respect! :D
1a) Abusive or unhelpful posts are not welcome
on this site and are always removed!
Which begs the question....Have you read the forum rules.
Thanks sbgasman.
Not being a gas engineer I wasn't aware that changing the fan came under "gas work". Had no idea it was part of the combustion chamber.
Thank you for pointing that out.
That's why I wanted to ask on these forums so qualified people like yourself can educate me on safe practices. (If I hadn't of asked the question I wouldn't have found the answer)
