Ariston Front Loader not letting water in!!
17 Mar 2011
Victoria
Hi I have an Ariston front loader Margherita 2000 AL109X that has suddenly decided to stop working!! The door locks as per normal when I set it to a program the light flashes and then stays on but then that’s when the problem starts the machine won’t allow any water to go into it anymore, even though the taps are on and so because there is no water in the machine it just sits there with the door locked not doing anything at all. I have tried resetting it both on the machine and by turning off the power at the wall this hasn’t helped all it does is unlock the door. I have also checked the filter that is fine. Any suggestions please???
If the motor brushes are worn is it worth getting fixed or should I buy a new washing machine
Thanks heaps for that! I have no idea how to fix the machine myself but it sounds like it is worth saving so I will call a repairman and get it done. I guess I was just making sure that it was worth getting fixed. Thanks again
