I'm trying to keep my Ariston Genus 27 going but noticed recently that whilst the DHW is heating, the burner keeps going out then relighting. The pump continues to run and this happens until the water reaches the required temperature.
The DHW expansion vessel requires replacement since water comes from the schrader valve when tested. The 7 bar temp and pressure relief valve also leaks a little but constantly; more so when the pump/burner is running. I can see this from the tundish and have ruled out the other valves.
My question: is the knackered expansion vessel responsible for the burner cycling and also does it contribute to the leaking 7 bar valve? Is it likely I will need to replace the 7 bar valve or should I do the expansion vessel first and suck it and see?
Any advice appreciated.
[/quote]
[/quote]
