before writing this, I did a search so that as not to ask the same question twice! I have a seven year old Ariston Genus B Plus 30 BFFI. I have always serviced it myself as I installed it, never had a makers guarantee but I'm two years past that! Today it shut down, quite dramatically, spraying water out of the pressure relief valve. I think I've diagnosed it, but I'd be very grateful for some input. If I press the start button with 2bars of pressure in it, the boiler lights, the fans run, but the pump doesn't run, the pressure relief valve (the 5 bar one without the bleed pipe) blows off and the top of the pipes are extremely hot and the bottom cold, the body motor was hot when I realised that the heating was off, but the pipes in and out were cold. I suspect the pump because, I get a reading of about 112ohms across the blue and the brown wires, but nothing between the blue and the black and the brown and black. I got a falling voltage reading across the condenser, not a very good test, but it would seem to be working. If my thinking is right, the blue is neutral and the brown and black are the two speeds, one of which would appear to be in open circuit. I'd be very interested in an opinions on this!
Regards, Matthew
Regards, Matthew
