ariston genus intermitant fault
7 Apr 2008
Yorkshire
i am a RGI,have been called to a genus he with a fault, apparently boiler shuts down to code A01(no flame after 7 seconds)when ch is on and a call for dhw is made,spent an hour with heating on and trying taps and shower but it seemed to operate ok, anyone come across this? cheers damian
this is the PCB if you fire it up and look at the electrode through the window you may see it continue to spark as the rectifier in the board has gone its very common this boiler has a 2year ari warranty,good luck PS if you change the board you will see on the left hand side a row of pegs marked 1 to 6 move number 5 to the left and leave it there.
