Help needed please with an Ariston Dia 20 MFFI CE combi, around 10 years old.
The boiler was refusing to fire up at all. Called out an engineer, who checked it over and diagnosed a gas supply problem at the LPG tank - a faulty UPSO/OPSO valve. Spoke to the gas company who own and maintain the tank, and they said it probably wasn't faulty and talked me through resetting the regulator, which had tripped. Boiler fired up first time after the reset, and ran fine for a few days.
The boiler actually operates normally when running. However it is incredibly reluctant to start from cold, either CH or DHW. The fan comes on as normal but there is no igniting of the burners and the red lock-out light comes on. It usually sparks, but occasionally there are no sparks for a while. It may fire up after repeated pressing of the red light (20 times or more), but sometimes it won't fire up at all.
I'm curious as to whether the non-starting is still a gas supply problem (ie. a faulty valve like the engineer said), or if it is an unrelated ignition problem. And if the latter, why is the boiler so reluctant to fire up initially when it is happy to do so once up and running?
All help gratefully received. Many thanks.
