Here we go see if any body can work this out for me please !
Central heating works all ok but ! no hot water !!
I have replaced the main pcb also the magnetic flow switch today the main flow block and a new flow switch again also descaled secondary heat exchanger.....but still no hot water !
Now here is the odd bit ! 3 wires to flow switch red power. white and pink signal to pcb to fire up if i bridge out white and pink "it" fires up and hot water ! also if i place an extra magnet on the flow switch "it" fires up
Please any one......why wont it work as it should....and yes i know its a ariston !
