The boiler in my house is about 4 years old and over the past 12 months has been tripping out every few months with the Ignition Failure (lockout) (red) LED coming on along with the Fume Sensor (yellow) LED.
In the past I have left it switched off over night and then it has sorted itself out when I switched it back on after pressing the Reset button. And it has always coincided with heavy rainfall or winds.
Until now. The 2 LEDS are always on and leaving it / resetting it doesn't change things. I think the pilot light is out and there is no "motor" noise which normally happends when I switch it on/reset it. Its just "dead" and then the 2 LEDS come on.
Now when it was first installed, it went wrong a few weeks later I think with the same problem. The engineer said that the outside flue had been fitted at a slight up angle and if it rained heavy some of the rain could go down the flue, which is pointed 90deg to the boiler, and sit in the bottom of the Fan. If this happened he showed me how to get rid of it by blowing down the Vent from the top access bung of the boiler which would clear any water from the bottom of the Fan. And it worked.
Until now. Done that and it makes no difference. Which is strange as we've had a lot of rain these past 48 hours.
I've taken the covers off the boiler and can see where that top vent pipe connects to the Fan. Next to it and connected to the Fan via a plastic pipe is an plastic Air Pressure Switch which I am guessing is comparing the air pressure inside the Fan with the ambient pressure on the spare inlet to the switch. Assuming again that if there is a difference in pressure then the switch doesnt switch. There are 2 red wires on the switch which look to to be going to the main PCB. If the Switch is working normally, are those red wires effectively connected together by the switch ? ie; If I were to connect them together that would bypass the Air Pressure Switch temporarily to see if the Switch had failed ?
Failing that, is there anything else I can check before calling a boiler engineer out ?
I have the boiler manual / fault diagnostic chart etc if that helps
thanks
thanks
