Problem on DHW. The boiler works perfectly on heating but when hot water is called for the the flow is good (normal) the temperature rises (on the indicator lights) to 70, the water is nice and hot. After a few seconds the flame cuts out, the pump keeps running and the flame reignites after, say, 20 seconds when the temperature is lowered.
This may happen once, rarely twice then the situation remains in balance with a good continuous flow of hot water for as long as you want.
I have looked at a previous problem on the forum and it mentions a clip type temp. sensor on the lefthand boiler pipe but the sensor on mine is fixed on the top elbow as it enters the chamber.
About a year ago this forum was a great help on another problem of which the advice I took was to fit a new secondary heat exchanger. I also fitted a Magnaclean unit as well.
Everything worked perfectly until about a month ago when I drained down to change a radiator. I have vented all the radiators many times and also the vent above the pump. The DHW temp control is set on max.
Your kind advices will be greatly appreciated, regards...Ivan.
