if needed to connect 2 armored cables in the ground (grass) is there a certain
junction box required and also a minimum depth?
Holmshaw, I have heard this before, where does it say that it must be at this depth?The minimum depth is 450mm and the cable should be surrounded by sifted soil or sand and marker tape should be laid at about 150mm above the cable.
The "National Joint Utilities Group", have a look here, you need Vol 1.
BS7671 Reg 522.8.10 ......suitable marking tape as per Holmshaw........buried cable shall be at sufficient depth to avoid be damaged by any reasonably foreseeable distiribance of the ground.
