A friend has asked my opinion on a survey for a house purchase which is 3-4 years old, there are a couple of electrical points to be rectified prior to advance. I have not seen the installation so i'm passing on the buyers description, of the report and the situation.
1] Cold water pipe not earthed - It seems to be plastic as is the majority of the heating system but dhws seems to be metal.
Assuming this is plastic, which seems to be common these days I don't see a problem.
2] Armoured cables from CU to shed CU and garage CU incorrectly terminated - CU's are plastic and armour cables have the armour run in sleeving direct to the earth bar at main CU only. These were add ons and have certs.
I have seen this quite a lot in the past when the glands were more expensive and still do see it in resin filled joints. Assuming the mechanical issue is elsewhere and not at he CU, personally I see no actual reason for fitting a gland per se. Any first thoughts before I see it?
BTW Every circuit in all CU's is a rcbo
