6 months ago we renewed all the radiators in our house and 90% of the pipework (replaced microbore with new 15mm). In total we have 6 large double radiators and 4 medium singles. The boiler and pump were not changed.
When the system was first tested, it was filled with water and run for 1 day to check for leaks. Once no leaks were found, it was drained down and filled again this time with x100 inhibitor added prior to filling (one bottle).
All has been good since then but when I checked in the F&E tank today I found that the water was dark brown and a layer of orange 'scum' had collected on the surface. It looks like the system is corroding quite badly despite the x100.
I don't believe there are any leaks in the system (that might cause dilution of the x100) as the system was run for one week after it was commissioned with the mains feed to the F&E cistern switched off and the level in the tank did not drop.
I have also seen no evidence of 'pumping over' that might cause air to dissolve in the water. I started and stopped the system while watching the vent pipe in the F&E tank and no water flowed out of the pipe.
I have turned off the mains water to the F&E cistern again to check if a leak has developed over the last 6 months and plan to clean the system out with x400 for the next few days before draining down and refilling this weekend with two bottles of x100 added.
Is there anything people can think of that might cause this corrosion and anything else I should try to fix it?
Cheers,
iep
Cheers,
iep
